In March I bought a boat with a 1990 Force 150 on it. I started it last Sunday with hose and muffs attached. It started right away but I noticed no stream of water coming from the motor. Came home and checked out past posts regarding impellers. On some posts they talk of pee hole. Is the pee hole the same as the idle relief holes? Where should the water come out? Are muffs the best way to run an engine on land or should I use a tank of water. I'm new to Force motors. Any info would be useful. Thanks Bill Mc I'm going to change the impeller, cheaper than a rebuild. What parts are needed, any gaskets or seals to change? Are there any web sites that show the 150's parts and part number?
