Testing Help!!!! Oil Reset Unit
john122661
Does Anyone Know How To Test The Low Oil Warning Reset Unit. I Have Two Manuels And It Does Not Tell How
hankll
Re: Testing Help!!!! Oil Reset Unit
On a 87 Suzi 150 SS, had same question. Doesn't seem to be a way to test it. Didn't seem to be working. Browns Point said to disconnect, had no need for sensor for motor to run properly without it, just manually check oil tank level. With Low oil sensor bad, it caused my 150 to run on one bank of cylinder in protect mode. Have had no problems with mine with the sensor disconnected, and just keep the oil tank topped off before each trip out on the water.
john122661
thanks i was thinking of running pre mix any way john
