nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,090
Getting ready to try to chase down a possible overheat (after I verify it and clean out my heat exchanger). It's a new/old gear housing that didn't have any issues (that I recall) when last used time around 2 years ago. I only used it for about 10 hours at the time, and had just replaced the impeller. Before I pull it yet again, I wanted to test the flow of the impeller.
1. Plan on pulling the line coming off the HX and timing and measuring output, I guess at idle. I've seen different specs for the numbers--anyone have anything definitive?
2. I assume this has to be done on the water v. muffs?
3. What's cooling the exhaust while I'm doing this? Won't I fry my exhaust bits?
