Testing Manifolds Question
Volphin
I read over the sticky on using acetone to test manifolds for leaks. Nice write up! Can you do so with the risers attached? Will it toast the gasket?
Re: Testing Manifolds Question
Ayuh,.... The whole Idea is to remove the risers, to clean, 'n inspect the gasket sealin' Surfaces....
