Testing yamaha O2 sensor
ssoileau
Can someone please explain how to test a Yamaha o2 sensor with paper clips. 200 hp OX66
ssoileau
How do I probe the connector? Do I stick the paper clip in from the back on the connector following the wires?
ssoileau
Do I leave both connectors connected when testing. I did test the heater connector and it get hot when the key is on.
wrench 3
You can slide the paper clip in from the back beside the wire but be careful not to damage the seal. For an on the engine test leave the sensor connected to the harness. For a propane torch test unplug it and take it to the work bench.
