Re: Texas state law, CROSS YOUR TRAILER SAFETY CHAINS!
The benefit of crossing the chains would be: no ticket.
The bigger issue is the law says the chains must be of adequete capacity to hold to gross weight of the trailer.
Not only chains but the hardware on the ends too.
Also, chains should be attached via proper chain connections. Welding a chain is not a good idea especially with high-test alloy chains. And too many under experienced welders will put too much heat into a weld, signifcantly weakening the chain link.
Simply bolting the link to the trailer is also not the best, but certainly a very common method.
This is a pretty standard looking setup for a small boat trailer. You could cross them, but what would be the benefit?
