Thanks everyone! ‘84 115 TOP rebuild going!
ianmoore
Question on the throttle linkage. The throttle housing(2 pieces that hold the spring together) has some vertical play in it. I found this both times I have put it together and couldn't get rid of it. There is about 1/8" between the 2 pieces. I don't think it has any effect on the timing, but I wanted to see if anyone had run into this. Maybe this is fine and how they are.
Also, its a little confusing with the lower plastic washer. The linkage goes over the engine arm with the marking and into the throttle cam. The parts list shows the order of the parts, but doesn't show the engine arm, coming off the block, so its hard to know if that washer(#21) goes on top of the arm, or the cam.
I have tried it in both places, and i can't tell a difference with one seeming more in line with the rest of the linkage or not
