barato2
Thread starter- Joined
- Dec 7, 2010
- 2,956
Re: the 1967 Holiday 18 and Multiple Boat Syndrome
i should be working on the house, but what do i do? that's right, work on the boat! :embarassed:
first pic is sort of a parable: if you add LEDs to your dash (to indicate when the float switch has kicked the bilge pump on) and then epoxy em in place, you want to be REAL careful with the thin flimsy wires hanging off the back of them. break one and you're having to do this:
[/URL][/IMG]
with the Dremel so you can replace it
other than that, i got the ceiling panels rough-screwed in place (still need to trim the foam a bit more and re-epoxy around the drilled holes)
[/URL][/IMG]
[/URL][/IMG]
the alum bar is hiding/supporting the edge (where the oak panel gives way to the birch) of the panels and will eventually be screwed in with more substantial hardware....i just use the #4 stuff for test fitting
