Re: The beast comes to life!!!!
Fatty, Most fuel pumps have a couple of check valves to keep the fuel moving to the carbs. I did not like the fact that your site glass (or sediment bowl) kept going nearly empty.
The reason I suspect it is running on two cylinders is from the sound and the lack of churning of the water in the barrell. You can put her in gear at idle speed w/o issue, as long as prop has clearance. Revving her up in gear will empty the barrell very quickly.
