Re: The dependable eska
mat_man,
Snip... I would use a heavy duty hydraulic hose and double clamp with stainless clamps. I think it would be very simple and easy and would last much better than Capt_Don may expect. If you have ever seen the drive coupling in a washing machine it's done much the same and they last for the life of the machine.
I would have more faith in the heavy duty hose than the garden hose. The hose clamps would have to be thread locked and evenly spaced to reduce vibration. Ever used an impact wrench on a airhose with a hose clamped fitting? The clamp will constantly loosen from the vibration of the wrench hammering. I have just the right tool for installing the clamps. They would be two turns and then pulled extremely tight, folded over, and then the tabs bent over the end. I think these are Band-It hose clamps. Haven't used it in a while.
The washing machine coupling is under a little different stress because the motor is electric and not producing the power pulses as a 3.5hp single cylinder B&S engine.
Now on this Sears 4hp I think that the lower unit can be assembled while the drive shaft is still inserted in the crankshaft. So, I can attach the driveshaft to the crankshaft and then set the motor in place. Then assemble the lower unit.
One note for future reference: the pinion gear on my 3hp Johnson fits the spline on either end of the driveshaft. If the Eskas, Clintons, or others were the same then an old pinion gear could be a source for the internal spline for these repowers.
All the above assumes that you want to disassemble this repowered motor at some point. However, for a one time deal the old weld the shafts together through a hole in the exhaust housing works rather well and has been used by me on several motors of various sizes when the crankshaft spline strips and the owner takes the cheap route.
Capt Ron
