ThrottleBack
Thread starter- Joined
- Jun 15, 2013
- 242
I bought two 14ft Jon Boats yesterday, one was ready to go fishing and this one...not so much. BUT I love this boat because A) it was $50 for boat and trailer (father passed, they wanted it gone) and B) It has an open floor plan, casting deck, and a front plate for the trolling motor and those are the three things i was hunting for. So I'm stoked.
The boat is a 1977 but the title has no indication of who makes it. Have not had time to look for any type of plate or markings yet. I named it The Hulk because it's green and because the home made trailer it's on is heaaavvy. My god is it heavy.
Issue #1: The wooden transom is gone. Well almost some of it hasn't rotted off yet. I have some thick non-treated plywood around here I am planning to water seal and use, but I am unsure what thickness is proper to use on the boat. I can't really measure the old stuff it's all rotten and swelled. The outboard I am using is a 57 Johnson CD-15 5.5 HP if that matters one bit.
Issue #2: If you look at the two pictures of the drain plug you will see that it is out of shape and has caulk all around it. Now I put in one of the five or so different plugs that were mixed in with the rotten wood remains and filled the boat with water. It did not leak. However being the paranoid person that I am my thoughts have me wanting to just permanently seal off the drain hole. My boat is stored covered under a car port and I plan to put an electric bilge pump in so I'm not really worried about being able to pop the plug. What I'm worried about is sinking. I'm thinking the caulk is there because the drain is misshapen and likely wasn't sealing right, but I plan to remove the stuff and see exactly why it's there for myself.
#3 is more of a question then an issue. The casting deck has a circular opening in the center of it, I'm guessing where a pole used to go for a seat. I can look inside and the foam all looks fine BUT the boat has been outside uncovered for god knows how long. Do I have to take the deck off and replace the foam, and if so how does that metal deck come off, or can I just cover the hole and go on with life?
Question #4: It already has a transponder for a fish finder along with the wiring. The mount says "Hummingbird". Anyone have any guess as to what Hummingbird units will work with this plug and transponder? If I can just grab a unit on here or ebay that would be great.
All in all a great boat. I don't see any major dings, the bench seat is actually solid it just has a crap wooden top on it thats coming off. I'm going to just remove that board and ugly carpet all together. No plans to re carpet any of it. The boat and outboard are getting a backyard camo paint job in preparation for some duck hunting. It's already setup for lights but all of that will come off and new stuff will be put on. I don't like using other peoples messy half assed wiring.
Thanks guys!
Edited to add a question:
My Minn Kota is the typical off the shelf one that screws onto a transom by pinching the transom between a plate and its two hand operated bolts. How can I mount this motor to the existing plate on the bow of the boat? I don't feel like buying anything I can just build what I need. Google searches are only showing me what to do if the boat has no mount plate already.
Thanks guys!
