nymack66
- Joined
- Aug 5, 2009
- 356
Re: The Johnson Curse continues...
Please check your Reeds very important and is not costly to do ...
Do you have a Tach and temp gauge installed? Important for benchmarking you will see the variations with every change you made.
Change the high speed jets back to 62D, on my 140 when I removed the 64d back to my stock (62d) WOT increased at lease by 500 RPM's and my running temp increase by or about 5 degrees with the 64d installed I was also loading up at idle and trolling and bogs at throttle up etc. Check your manual for the correct operating temperature for your engine. Mine is at 130/135 range give or take 5 degrees on water temperature and air temp on any given day.
I have dual probes into each cylinder head for accurate monitoring, buzzer in my opinion is useless, it gives you a static warning not a proactive warning where you can clearly see a rise in temperature or failure to run at the correct operating temperature, which is critical for a Outboard to operate correctly.
Also I am assuming your lower cowling and engine itself is clean and free of dust and loose foam from the inside of the cowling, recirculating foul and contaminated air will get sucked into your carbs clogging the idle and intermediate jets, use a air compressor and blow it clean you can also use a can of compress air and blow the air jets out,for your next rounds of testing. Notice you do not have air filter? We focus on clean gas and sometimes over look the other ...
Keep us posted..
Keep us posted..
