- Joined
- May 19, 2001
- 26,116
John Deere 2240 4wd finally made it's way to my yard. It has not run in about 6 years, has a new clutch, needs TONS of things to get it running
It's a 1981 diesel 3 cylinder 50 Hp
Has a 145 Loader - That needs TONS of welding
Tires - Bad Rear wheels need replacing too Needs tires.....
or and the Bell Crank needs replacing because there is more free play in the steering then in a bumper car!
The seat needs some help
I figure with 4WD, some chains (Which I don't have yet) and the bucket I might use it for the driveway in the Winter
I am in the process of removing the bucket to get to the starter motor. What a crazy design but that's the way it works. The started will be replaced with new when I finally get inside there. To remove the bucket I had to remove 3/4" bolts taht my 3/4" impact gun would not move......... Cut off wheel did the trick
Since it does not run....... it does not move - yet. It is real project.
So far I have learned that -
If it is John Deere - it costs real money
It is heavy (about 7500) when all the tires are loaded
and just like a boat - CHECK everything (twice)
It has been neglected for the past 6-8 years but deserves saving
