The Legend of Chug A Boom, or how a man and his tri-hull conquered the garage???
loose rivet
Re: The Legend of Chug A Boom, or how a man and his tri-hull conquered the garage???
I did a similar boat a few years ago, the center V was worn through much like yours is. Mine had no drain plug from the factory, so that didn't become an issue.
What I did was to sand the whole boat as you did, I finish sanded it with 100 grit paper. I roughed up the area around the damaged spots and patched those by welding in the cracks with Alumaweld rods, since all my damage was along one strake, I then took a length of aluminum angle and ran it from the front to the transom the entire length of the strake. The result was both a boat with a bit more of a keel for directional control and a wear edge for when it got beached from time to time. I did also have a few front corner welds to redo but those were minor. I also went over the inside of the welded areas with JB weld just in case but mostly just for cosmetics. I then sprayed the whole inside of the boat with bed liner, and painted the exterior with self etching primer and finally some gray enamel.
I used the boat for a season or two but sold it when I found something a bit larger.
The Alumaweld rods take a bit to get used to using, so practice on some scrap first. I used Mapp gas on mine but they say propane will also work.
What I did was overkill but the result looked factory when done and the added angle down the middle served several purposes, it both added some strength, protected the repairs and possibly other thin spots, as well as adding some directional stability that it lacked under power. (I ran a 20hp motor on it).
The aluminum angle I used wasn't an off the shelf piece of aluminum, I had a local shop bend me a piece of .040" piece of 5086 sheet aluminum and I worked it to fit as I welded it in place.
I also replaced several loose or missing rivets and the interior did get a coat of Gluvit before painting.
I coated my transom wood with epoxy on all sides, reinforced between the two layers of plywood with a layer of fiberglass as well.
Again, total overkill but I wanted it to last forever. The transom was painted to match the hull over top of the epoxy coating to protect the epoxy from UV exposure.
Woodonglass
On your patches I'd use JB Weld or PC-11 and coat the area and the patch with it prior to riveting it in place. For the Paint, you only thin it about 20% 1 cup paint 1/4 cup MS If you're spraying. If Roll n Roll I might not even thin it at all. I would use the Hardener though. But Hey I've never Owned a Tin Boat so don't listen to me...What do I know...I'm just an...
KennethfromGA
Hello all,
Long time no see huh? I've been busy with the house and work the last few months and have in total achieved almost nothing regarding the boats. Chug has lain completely dormant and aside from finishing sanding and removing the old transom not much has happened to red in awhile either. Though I have sourced a free 3.5 hp sears outboard for it.
(no idea if it works) The money tree is also being totally pillaged as well since the wife and kiddies are going on a cruise in August (while daddy continues to go to work mind you). The upside of this is that afterwards I've been promised a greater share of the pie for boat work. Hopefully this weekend I'll get some progress done on a motor stand for the Chug's Johnson. Till next time I'll be lurking around reading threads and dreaming.
GT1000000
Glad to see you still "chugging along"...
It happens to all of us...this thing called LIFE...but eventually we all get over it...:rolleyes:...:lol:...
Hang in there, brother...one way or another we'll get these things wet again.
saginawbayboater
Good to see an update Kenneth! Keep on pushin forward!:joyous:
KennethfromGA
w00t I actually got a little something done towards the boat project. More specifically I turned this old cart of my dad's,
into the motor stand for the 85 Johnny sitting out back of Chug.
By the time we finished it was too dark for pictures but I'm rather pleased with the final outcome. It was also fun to spend time with both my brothers and the nephews. I don't think there will be any strength issues even though the upright portion is made from an old bed frame since we braced it fairly well and my 270 pounds couldn't find any flex. Hopefully it will be coming here in the next few weeks then after my wife's cruise leaves dock I might get something done.... but don't count on it. ;-)
