the marine doctor
db1971
Re: the marine doctor
can i ask what problems are you having, or if you are.Because i have a stator problem or a switch box problem. Im thinking of buying both to liminate my problem. After some run time it will just dye and not start until it cools down.<br />77 merc 150 hp Help Its almost labor day.<br />thanks
The Marine Doctor
db<br /><br />It might be cheaper for you to go to a dealer and have them check out which part has failed.<br /><br />I know that up here in Canada the parts are over $300 each.<br /><br />You need a special tool to find out which is not working. A DVA meter.<br /><br />On the other hand...You can prob buy a DVA tool from a dealer and find the problem yourself. $150.00 from Mercury. <---if memory serves me right.<br /><br />Snap-on also makes a DVA tool.<br /><br />TMD
The Marine Doctor
runningbear888<br /><br />We stock the item you have requested. It lists at $392.85 Canadian.<br /><br />If you require it email us at.<br /><br />marine.ron@shaw.ca<br /><br />TMD
