Capt Sully
Thread starter- Joined
- Jul 26, 2012
- 274
I want the install a second battery to run only my radio's, GPS and some other things. I want to install a Perko switch. Questions are, do I pull the + lead off the starter battery #1 and connect it to the com on the switch ? then add a new lead from the + pole on bat #1 to the #1 on the switch ? do the same with bat #2, pull + lead and connect to #2 on the switch ? then have both - poles on both bat tied together ? connect all radio wires and others to bat #2. this leaves bat #1 with only the cables for the motor ? what do you think ?? Thanks,
