The Project
CabinFevah
I find that one of the keys to being a successful mechanic is keeping your emotions in check. Well, I've been a bad mechanic. I bought a 2002 Glastron with a Volvo Penta Chevy 5.0 GL E that overheated. The people were smart enough to have it taken apart and left in pieces in the engine compartment for 3 years. I got it for a song and will be singing that song over and over again while I rehab it. My plan is to buy a long block and take the accessories from the original. I have heard that a 5.0 and 5.7 are almost interchangeable. Could I make the jump and still use the 2 barrel holley off the 5.0? Are there other pit falls I should be wary of? Thanks in advance.
jtybt
Re: The Project
A lot will depend on the year of the replacement block. A Vortec head needs a vortec intake manifold. A one piece rear main seal flywheel and coupler won't inter-change with a two piece flywheel.
Just match up the year block and you should be good.
45Auto
Re: The Project
I believe the carb needs to be rejetted for the 5.7 or you'll be running real lean and buying another engine shortly. I think Bond-O has mentioned the jetting differences before.
Don S
Re: The Project
Actually, the main jets are the same for both, the only real change is the power valve.
Have a look at this from the OEM Service manual.
attachment.php
Here are links to the manuals for your engine, you'll probably need them.
Engine = http://www.4shared.com/file/74506321/9da18d5d/7743372_Engine_Manual_50-57.html
Electric, Carb, Ign. = http://www.4shared.com/file/89977206/f5981829/7743454__Elec_Carb_Ign_30-57.html
Wiring diagrams = http://www.4shared.com/file/55944245/14d260c/7743606_GL-_GS_A_thru_E_wiring_diagrams.html
Outdrive = http://www.4shared.com/file/50982625/e2bdb42c/SX_DP-S_Service_Manual.html
CabinFevah
Re: The Project
Thanks everyone for the quick responses. Don, Thank you for the links to all the manuals, I bought the engine one but will now return it for more money for parts. Guess it's time to do some home work. Thanks again.
