oldslowandugly
Thread starter- Joined
- May 12, 2010
- 98
It may well be worn, it came with the motor. I'm sure it's shaved the beards off a lot of clams in it's day.
NEVER remove pitch, you can increase pitch (Efficiency) but you can not drop pitch without loosing bite.
Also, a 15pSS should turn roughly the same rpm as a 17p alum. That said, The ss prop cup is likely worn substantially. To properly test pitch, you need to stay with same design, only change pitch, not material or manufacturer.
Nice to hear from you again. Been awhile.
Couple of items here I question:
What difference in "bite" does it make which way you go other than obviously more pitch makes for more "bite" since you are moving the prop forward at a slightly faster rate per rpm.
To wear the pitch off a SS wheel you have to have a lot of miles on it or spend a lot of time grinding sand. Opinion!
Agree on the "To properly test pitch, you need to stay with same design, only change pitch, not material or manufacturer".
Good to see you on here too!
When you re-pitch a prop down, in order to properly set the geometry you have to literally cut the blade loose from the hub and re-attach at a lesser angle of incidence so you don't have the center section near the hub pulling more water than the outer third of blade. There is a formula for root pitch to tip pitch that has to be taken into consideration during the design process. We ran into this issue with the prototype Apollo in testing. It was an easy fix but takes time to recalculate and re-mold. If you just flatten out the outer half, even though you may keep the cup (which takes some hellish work) the prop will never bite as good because you have effectively removed the "progressive" blade geometry. You can't trim much without blow-out, and even though you may get more RPM, your slip ratio will go up substantially, and you have just set yourself up for cavitation burn. Think of how the best props we have are designed.....Thin profile, not only trailing edge cup but tip cup as well, which helps create parabolic rake and a true progressive design with low slip numbers. These items are added in certain amounts to create the best combination and some manufacturers (Getting very popular) are using the same blade attach point for 2 different pitches, 1 is a great prop and the next pitch up is just flat amazing.
I worked it out-slip factor 9. Methinks my biggest problem is too much crap on board, but this is a serious fishing boat and you know how that goes. I believe I will leave well enough alone for now and just go fishing. Thank's Mark, that calculator is incredible and I learned a lot from you. You have my gratitude Sir!
