FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
This rack is make of porcelain or some sort of porous material. it should have been steel what is it called because I can't find anything on it. This rack is bolted to the transom .
the rack would be the inner transom. Can this be repaired in the boat. Looks like it is made of porcelain. Can an epoxy hold it. I don't no why it cracked while install the rebuilt steering ram.
the steering ram is held in the boat off the transom it called the inner transom it is a very porous molded rack with smooth finish. for some reason it cracked and will not hold the piston cylinder in position when steering is used.
Ayuh,.... Got a picture,..?? The P/S unit is bolted to the inner transom plate, as far as I know,....
Usually 2 big but short bolts, one from above, 'n one from below,....
