the right alinement bar ?
ziggy
i need a alinement bar. ?. service manual says i need C-91-48247 or C-91-57797A1. will the C-91-57797A3 work as well?(this one i seem to be able to find) i seem to be haveing trouble finding the part numbers that the service manual says i need(C-91-48247 or C-91-57797A1)for my 72 mercrusier 165, model 1 drive. in this case all i want to do is to check alinement after pulling the drive to inspect it. (probably needs more than an inspection, but will cross that road when i get to it)
Don S
Re: the right alinement bar ?
ANY alignment bar on the market designed for OMC and Mercruiser will work on yours.
DHPMARINE
Actually you should seek a portside bar.<br /><br />DHP<br /><br />Unless you're in the front,looking where you have been.<br /><br />DHP
Originally posted by DHPMARINE:<br /> Actually you should seek a portside bar.<br /><br />DHP<br /><br />Unless you're in the front,looking where you have been.<br /><br />DHP
Ayuh,.........<br /><br />Then it would Still be a Portside Bar.......<br /><br />Port,+ Starboard Don't Care,........ Which way you're Lookin'........ :D
ziggy
but i'm right handed??? starboard handed? but if i look where i've been, then i'm port handed. my lord, i didn't know there was so much to be learned about alinement bars. so now i guess i'm lookin for a starboard sided bar now? right, um, starboard?.....i think?.... ;)
