The right prop please help me decide
timsmcm
I have a Lowe 1440m that I am doing lots of work to on the inside. Decks on front and back , flooring and trolling motor. I have a 1985 Evinrude 15hp motor that is just the bomb. It has a 9 1x2 x 10 prop. I runs great and I could not ask for better. My question is will I benefit from a different prop size with all the added weight? My boat is a lot heavier now and I have not had it in the water yet as I am still working on it. I had an older man that claims to work on outboards tell me not to use a stainless prop on these omc motors because the lower units were weak. I want to get another prop just to have an extra and wanted to get some opinions from others that have this motor. I would like to get a stainless prop but not at the expense of a lower unit.
180shabah
Re: The right prop please help me decide
You need to run it and get WOT data, then we can make recommendations.
Any reason you want an SS prop?
ezeke
There is a nice aluminum four blade 10 X 9 OEM prop that is for heavy loads - part # 176266.
boat1010
I wouldn't get too excited until I put the boat in the water and test it. If you were that happy with the performance of it before it should still be pretty close to what you had.
