OhioLowell
- Joined
- Oct 21, 2005
- 189
Re: The stRingers are out!
HAHAHAHA!!! I say to the weather gods, as I stand and spit into the wind. (not highly advised!) The weather report said that it would rain all day today. So last night I got the bright idea, I'll show the weather and put this transom in tonight. Surely I can do this by myself. Low and behold I can do it by myself!
I started about 7pm last night and worked until about 1215am this morning. However, everything has a good chemical bond. Thanks to the longer working time of the epoxy I was able to start the next layup long before the first lay up was kicking over. The fillets didn;t really start to get warm until I was laying the glass tape over the fillets.
The fillets consist of 3/32 milled glass and shredded chopped mat. They are a radius of about 2.5". I thought that 1/2 gal of the 3/32 milled glass would be enough thickener to do the entire project. WRONG!!! After the transom was installed and set in place (prior to building up the fillets) the 3/32 stuff was just about gone. Over the fillets are 3 layers of FG tape. The first layer is 3" mat, next 6" mat, on top is 12" 6oz cloth.
As promissed here are the pictures:
This is a shot of the transom installed. There is no fillet build up in this pic. The transom was set in a bed of thickened epoxy as well as thickened epoxy wa spread on the back of the transom. The transom was held in place with dry wall screws through the old transom. The screws will be removed and the hole filled with thickened epoxy.
The next 2 shots are of the build up of the fillets. There could have been 4 shots here but I'll spare you the repetition.
A LITTLE!
A LOT!
This is a shot of the bottom of the transom after the tape has been applied.
Here is a shot down the new transom.
Here are shots of the top corners of the new transom. This is the best shot I could get of the fillets.
LEFT
RIGHT
Here is a final shot taken this morning in the day light.
There are a few little air bubbles that I missed last night that I can see now. I'll inject them with epoxy. In hind sight, I'll be sure to have more thickener on hand next time.
Now onto the stringers.
Thanks,
Lowell
A LITTLE!
A LOT!
LEFT
RIGHT
Thanks,
Lowell
