The well traveled 1979 Starcraft 18' V5 SS
Watermann
Pouring rain outside but inside the hangar I'm staying warm and dry. I've got the smalls that take so much time to clean and restore. Consoles tore down, old blinds removed and paint stripping in progress.
Splashwell is crack free but had some ferrous t-nuts that turned to rust long ago that were holding on ply. Working on breaking the SW down so I can decide to use it as is or shrink it down to size similar to what Candutch did with his. Either way the solid rivets need replaced in it anyway, half of them are no good and the seal is rotten.
Got the last mauled can of liquid stripper that doesn't have that useless gel stuff and a pic to show the misery that lays ahead. :cold:
y4mDzo0a-SDInkR35_N6MfmU4NDg8_mjp9dt1ujXAcJz2QKTe2iM0CSbaoMSkM_pjB0vl-gaFoVv_BRSsLZA8GmjASGHll5j69c5Te41Uh-AaBj2f1DHp-MvkYG_DikvJ1Mdyv1lsq2NDwF_yvS03w4tiE2gBmnQ8QsTJTup2bGUR7J79ztAV_M7LJ8ViEYHDDwvlD6XzGfWSnOYKd4dnZZCw
The speedo got removed and tested out with the compressor, it work great and the admiral was recruited for the clean up on it. I love the SC logo on it but the character dent not so much..Anyone know if it;s possible to dismantle gauges with ruining them?
y4mRFDmI7JTj94f90oDO-m9adRg13Qkw01cxUFiAmbKll2qb8uotfauN8ChW56LmAnaQ3cGVEO4VJQTf12Ejt8mgFLgJaDuWSb9ZNgCP-JYjwj1-1lX_ohCXr3LDuGP56iZ9mxQRDzWHkz82M9A8VDGHiRsDLxi4ugIDwGcGRYbQhDfONUJWBa8L9TVZ5GU8B26eaEg0tBhM4wgCpvIZl6ysw
GA_Boater
Some gauges can be opened, some are tough, WM. Got a side view and rear pic?
Watermann
GA I didn't get any of those type pics but I can. I already bubble wrapped and packed it in a box, the metal bezel doesn't even budge and there's no slots around it. The back has the 2 posts and taking the nuts off them did not loosen the plastic case from the bezel. Due to the age of the case I'm afraid to do much uni-brow work on it for fear it'll break. I hope the light bulb works because it's riveted in. :grumpy:
Candutch
"Anyone know if it;s possible to dismantle gauges with ruining them?"
I would think it's very easy to "ruin" them. 😂 JK, I don't have a clue. Glad to see you are getting at her right away WM. Looking forward to the progress.
GA_Boater
I asked about the pics because it looks like the gauge is an outer shell with a gauge nested inside. But loosening the two nuts on the studs would have shown some wiggle. I wouldn't be aggressive with it either. You won't find many of those with the SC logo.
Just call the ding patina. ;)
64osby
I was able to pop my old tach apart. It was a pressure fit. Took a lot of effort. Second time I had to pop it apart it broke the lens. Luckily I had a spare.
Watermann
Happy first day of spring to all you Starmadians!
Yeah still here, plugging away, slogging along with the clean up. Got the toughest parts to strip all done the consoles and splashwell. I plan on stripping the hull before going at the rivets and since I just got in an order from Jaycee of several hundred rivets it won't be long now before the BRRRT sound fills the air.
In the meantime work continues on clean up as long ago a few construction tubes of sealer were used. It looks like silicone but the AL under it is like new.
The tank support sheet... factory sealer, silicone?
y4m3wr-th6s1A7KMeMt7Vq8Y1ug-33kP1uvbthNOHelwL0eK_99tu4dFcY6urEh_EZWVQ7TGS37TtOGP1qv7Aw7dclGaStxGrnfEjGKxHcTygQSGJK7RcC3xcyjddYPAgUxKMYkWTDbL-cxRQbCxNSlNWVhmfm-YqQi-XmQl38EyyZ_2zcDRvSOqACacfYK2YhJKNAoFvCHE3e3RJtFNOMMeQ
No holes for rivets holding this tank support down, only the sealer, SC factory even left a mandrel under there.
y4mujkJRUYXcrO1d_FMpwRglDQkLM1fHcwkFzZqUSD7LuMPv4dztkOCxoQSPixh4klLOn-b3-3eB0tUB9kkjc1o6lk25sUnuAWtZa59iaazbIIetAODfvbOJt36tKYRxgdxej4fyoijzIk5QyyVcm8iXl5TZyWSj4V8Us6NRLhz8kRZ_R4JuTTSuzh80QbilEqurPOlW6SgGoLh9iVTJRjfEA
All of the blind rivets on this boat will be replaced, the steel mandrels are just powder.
classiccat
Nice to see you getting down & dirty again Agua! :thumb:
I thought my ribs were cleaned-out of old steel mandrels & flair-outs. After a weekend of pounding my keel-reinforcement into shape, my garage floor is littered with them! :eek:
Watermann
Yeah CC people just don't realize how damaging steel is to aluminum. SC used steel t nuts to hold panels on and the AL where they were attached has a big hole corroded out. They put SS machine screws into the steel nut... what a mistake just to save 5 cents.
I'm going to flush the ribs out real well as it rained inside the hull and now there's white rings forming where the water dried up. More rivet drilling and support pieces need to come out to be cleaned and there's more silicone to remove inside. :grumpy:
Also I was mistaken that fuel tank support panel had 6 x 5/32nd blinds holding it onto the sealer. :cold:
wheeldriver
After finding rusted mandrels in my SS when cleaning it out as well. I wondered whats under my ribs that I can't see. I taken a large neodymium/rare earth magnet and touched it against the center of each rib in the middle of the hull. On a few I heard a clunk of something bang against the rib at the magnet. I used a string attached to a magnet and feed it into the rib up at the gunwale. Used a second magnet to draw it down to the center of the rib at its lowest point. Ended up pulling out a very rusted nut of some kind. On a second rib I pulled out a fragment of metal that was very rusted, WTH!
Enjoying the thread Watermann, I'm jealous!
oldhaven
You are speeding right along. I guess practice makes perfect. Having done this all before must make you pretty fearless about tearing things apart that give me pause.
Ron
Watermann
Interesting idea WD, magnets to remove the steel from the ribs, this V5 doesn't have limber holes either. I'll be interested to see how much crud falls out once she's in the turtle position with an air hammer running on the rivets.
Ron
Well Ron I had some help on her already, Glen did the tear down and filled a dumpster. :lol:
Now I'm pulling apart every last bracket and support piece that was blind riveted or screwed on. Each one is being wheeled clean of corrosion and washed with cleaning vinegar then rinsed so they're all spotless.On the Chief I primed and painted every last one of them too. Not sure about doing that this time around though.
I'm onto the inside of the hull where there's scores of blind rivets remaining that need to be removed, it's pretty dangerous with all those sharp pokey blinds. Next I will strip the hull paint off and tackle the smeared on 5 gallon bucket of carpet glue on the inside, hoping just to knock it down some.
dozerII
You shouldn't get to much out of the ribs Rob, she was turtle once already and riveting the keel strip back on shook her out pretty good.
FrankenCub
Now that's a great idea ! I stripped an old HDD just now for this use ;)
Watermann
Finally have everything out for clean up. Every blind rivet holding the 2 piece gunnels together are off for clean up and repair.
y4m-TR66-xoJsdpwAgIAt7JVnkgFIetB_cjaIgpI9FgDGbSShk12IprGVJt1VMBIxmaC3du3qbOpM5wXZXoWBy36uzZntENqiyfksVSRqATHjCPWhyfeoFrPI2OszhqZWAYbM4SSkoomgMcQWxd6XrQp_d2ithRiEwsXQJWEDPkfAbPAVZP1cRG4Jwyd-zhf9Kd1w3H09y-OzA5WaVaCYTpeg
Transom out, not bad at all the inside skin just needs cleaned there's no pitting. :)
y4mLadpPlRNp2sgXzJr90PetO8Sd6GTblFOx0Lbd7Fk1wMKgM28js0TwgzXeZeLzLGp4Ek09na9Mq_AFeYLLuMvU7RGMSekes32JENl7HFAFFUQorNZJtFprFxLQr10NU0iZqEo7HRzrloII0xgHx1He7s7OgtNnZvtG8iuCtaFBcYRkf6gbi98L7koHQ7zyTmST8kmi55-PBpl_XwGtMjVgw
Lots of glue used for the carpet, from one end to the other all over... :facepalm:
y4m-XtFPLaTb8d6rW77w8Lds23gTgY1fmpUoMzqDaN6zLzqcjcm1piH5E9dZPO40mly8ogBXsUaFOIE8j9H3hVnjGawCRAzC07AJBLqu2jLBfdQMA4KLAKRzbgpvqJlIIYpgxrvscA2DbsNH1HdIfW8Yw9dK74gsPSKrBhcdf9EzegE158ptdUWa8QVljt0BUbO3r3csDMn21EChcfTUOfG0g
Bummer the only piece of mahogany in the boat was split and it's not even rotten. Oh well I'm making the front bow cover flat so I didn;t want the bowed piece anyway. Marine ply will replace the bow cover supports.
y4mKdkwJRbjSs1HUsS-q7BuD0NZebkb9PHGrfc8aqEiD6rtIkBCOGVrMdJ_OXwqzUMP8qpuTrcIkqZ7MqzUbY3XfLyOv8Ftu2Nu2VG9K51q_4hnJfl6PYh8c6A7wEtLbLZVI2-1me5obE8fBmE0T5Hg-gcqvzHGJmu36DG1TvDZBHwuMynuLamlzJRno6UxiEuniY7UlNDCHHFXbkLX8_T20g
Back to the grind I go with some tough weeks ahead of me cleaning everything up. :rolleyes:
StarTed
Hey, you're putting me to shame. I'm jealous of your find. My little 16' seems tiny compared to yours.
I take it you have someone to put into the echo chamber while riveting.
Will be following your rebuild.
classiccat
WHAT?! No pitting? No galvanic corrosion? No clouds of alumina? Next you're gonna tell us that there arent any fatigue cracks :rolleyes:
Kidding aside...you'll be in rebuild mode in no time! :thumb:
coostv
That is one solid looking hull you have there! At the rate you are going this thing should be splashed by June!
Watermann
Welcome aboard Ted, lets hope for a smooth ride!
The spashwell had some corrosion and pitting on the flats where the pieces connect (yeap I disassembled it removing the solids) and there's a 1" crack from someone jumping up on the side wing where it connects to the gunnel but no stress cracks from use down in the pan. There's also a wear spot next to it that needs filled.
y4mMiKsNboSlD3zYqDwDqMCnNhOyo9F9GQwO-tVG55FeogQ6BnwMsc4sIiVhSemp2JhO7rZffvrGpXZ3O6HjrQpNlK2Sqkx8dCepkIZyNbS367ura0-Wzod-Fh7SAiEiD9Kgnut3ZnmsSW_UoZZ69gXPGxBtj0X0aoJNY41aBJw_LF6o16Q6CWmrmUOoVn9i-Fl0oAIX5SDKCLbgb_R6uutoA
Looking great there Water nice progress.
Thanks for the encouragement guys, but June is a bit of a stretch :lol: I forgot (almost) how much work goes into the clean up and I haven't even started on the hull repairs and 100's of solid rivets that need replaced on the old gal. I've just about got every single one of the blind rivets out, all of them have had rusted out steel mandrels.
