thermostat 1985 EL90TLCO
simplydave
is there one for this motor? I can't seem to find one on the parts manifold, just a water passage cover. Also, the manual shows a bubble back but this motor is a flat back, is that correct?
interalian
There are two thermostats, just below the exhaust cover. Major PITA to change.
Bosunsmate
manual always show the bubble back for unknown reason, maybe the artist prefers drawing that one. Make sure you get the gasket for the flat back they are way different.
I just drill holes in the back of the lower cowling which makes accessing those bolts easy and i just plug them with black rubber stoppers- looks good
simplydave
Thanks, I haven't seen the t-stats on the parts diagram though do you know what the part number is?
