netting one
Thread starter- Joined
- Mar 23, 2010
- 112
I have a 96 merc 350 chevy engine. open water system. Was talking on another post about running or not running a thermostat? Well it seams like they are very important. So i took my housing off last night and inside came out pieces of what i think use to be a thermostat. The housing has a plastic insert that looks like it may have held a littler thermostat? When i got the new one it came in a kit with many gaskets and o rings and a standard looking thermostat. The napa marine man says to remove the plastic liner and put the thermostat in the intake housing groove like the old style ones. Then install the correct gasket and im good to go! Im just thinking about it and is this correct or not? There is also 2 sending units screwed into the housing witch will be on the back side of the thermosat other than the top side with the old style? thanks dan
