acdc96
Thread starter- Joined
- Apr 23, 2013
- 412
I recently aquired a 1988 Nissan 18hp outboard from my cousin. The engine runs not the best but I'm in the middle of a carb rebuild. When going through the cooling system the impeller was completely shot. I ordered a new one and installing it this afternoon. I took of the thermostat housing and it looked corroded and filled with mud or dirt. I took the stat off and put the cap back on the housing without the thermostat. The Nissan service manual suggested if the motor was run in muddy, low water level, or in saltwater it should be ran without the thermostat in. Then remove a screw that flushes then motor when done. Is it wise to run the motor with out the thermostat??? I know in my other motors it's alright to run it in a short time but I don't to mess this up. Opinions???
