Thermostat closing position
3ric
Good morning. I have a 2012 Mercury 115 efi. I changed the oil the other day and noticed some water in the oil. Not a whole lot, but enough for concern. From my reading, the thermostat could be the culprit if it’s not closing completely. I installed a new thermostat last year when the boat was new to me. I’ve used it about 3-5 hours since then.
I pulled the thermostat and tested it in water, it does seem to be moving, but when installed, the valve never really fully closes. It seems to be perpetually open about 1/16” (but will open further when heated). I can put it under the faucet and water flows through almost freely. Apparently this thermostat is only sold with the housing and is $80, so I am looking to you all’s experience and familiarity before I just buy a new one. Should my thermostat be closing all the way when cold or is some flow appropriate? Is my thermostat faulty?There is a little notch intentionally in the valve that would let a little water by.
I would like to figure this out before I start investigating more costly sources of the water in the oil. Thanks in advance
Texasmark
I know nothing about your engine except that the water and oil circuits don't touch each other. Your water in the oil is probably condensation from humid areas and temperature changes. It happens in farm equipment all the time.
Possibly the engine design needs "some" cooling under all operating conditions....hence the permanent open condition. Agreed that most engines don't move water until it reaches the stats opening temp.
all marine thermostats are used as mixing valves and not true shut-off valves. in the outboards, there is constant flow
3ric
So you’re saying that it is not supposed to close all the way?
3ric
That does seem to make sense as there appears to be no seat for the male part of the valve. So Texasmark, you are saying that the condensation is normal? When I changed the oil, I ran it on muffs and drained, and I noticed a trace of water in the last bits that drained out. But I overfilled a little, let it set for a few days. But when I drained out the overfilled amount about 2-3 oz of very watery oil came out and then the rest looked great. Is that what i should be seeing with normal levels of condensation from that oil being in there a very short time? Ambient temp was in the 50’s
Texasmark
On what comes out when, oil floats on water. Lot of farmers drain off their condensation by opening the drain plug and watching the water come out and when oil starts coming out they plug it back in and top off the crankcase with the appropriate oil.
A 2012 Mercury, even if used in salt water and never washed after use doesn't seem like a candidate for pitting in the cylinders allowing cooling water to enter the combustion chamber and then into the oil. since Merc. prides itself on its corrosion resistance measures.
I have a 2002, 115 2 stroke. I haven't followed Merc's designs after about 2006 in that your Electric Fuel Injected engine is 2 or 4 stroke. Since you said "in the oil", I assume its a 4 stroke. Not familiar with that engine at all so I can't help you with potential problems like a gasket leak or other abnormality. Good Luck.
