Thermostat held on with flat blat screws?
Justinde
HI All
I just tried to remove the thermostat for an overheating 125 force ( 1988) after my recent repairs, and of course, even Superman could not move these with a screwdriver. My question is- how do you get them out? Vice grips? Rotary Hammer Drill? These bolts ( flat blade bolts?) would not budge. I am no fairy, but I wondered 2 things.
1: Is this the standard thermo install and
2: Should I run her without the thermo to 'flush' the engine of the **** and debris?
Cheers all- again.
tater76
Re: Thermostat held on with flat blat screws?
Impact screwdriver is your new friend Justinde :) Yup, it's standard :(
Justinde
I'm gonna file those *******ers flat and use a wrench. Then- replace them with a bolt. Thanks tater!
roscoe
Often times you can use a square shaft screw driver. Put a wrench on the screw driver handle a give it a little twist.
Second choice, impact driver.
