In reading an older post I saw where Bondo and All Dodge were speaking about the Check Balls in the Thermostat housing and one of them commented they were not used on Alpha One Gen II. So here's my question......
1995 Searay twin 4.3 Mercruiser 4-bbl (no original serials) with Alpha One Gen II drives. Both original motors were replaced in 2003 with Quicksilver Rebuilds. They have a tag on them saying Part# 807736 11 Bored .40 Mains .10 Rods. .10 S/N 90001?0 (second to last digit cant read). These are newer Vortecs than what was in boat originally. And yet, in installing these motors they didn't upgrade the cooling, nor did they keep the 1995 system. Both engines have the thermostat housing as found in the late '80s. Warm water system. 6 bibs. T-fitting with check balls going to risers
The above may or not be necessary for my question since it has ran that way for 17 years. Just giving you the full picture.
Port engine runs cool except for elbows which you cannot touch with your hand. Manifolds and elbows are new. No riser extension. Restrictor gasket. New exhaust flappers. Exhaust Tube not bellows. Ran garden hose is Y to make sure exited and didnt back up. Hoses and clamps are new. Impeller is new. Circulatory pump is new. Swapped Check balls and Springs from Starboard (no change) Clear hose from Thermostat housing to bottom of starboard side (of port engine) manifold shows air bubbles. Not a ton, but steady. Gut says head gasket. Compression test shows 160-170 per cylinder. Was going to block the four hoses to risers/manifolds and pressure test engine but couldn't generate enough pressure with hand pump. Will have to wait till boat is out to use compressor. Any ideas? Opinions are appreciated. Many thanks
