thermostat housing question #1
Cptkid570
Ensign
I?m putting together the thermostat housing on my 1985 Mercruiser 260 hp. Raw water cooled (not a closed cooling system). Boat didn?t have the housing when I got it, so I?m not sure exactly how a couple of the parts go together.
1st question is concerning the thermostat sleeve. It?s the brass colored thing in the photos. It has a sort of lip on one end of it and is open on the other end. Which end goes into the housing first? Is it like picture #1 where the lipped end goes down into the housing or like picture #2 where the lipped end is at the top of the housing and the open end goes in first?
Don S
Re: thermostat housing question #1
See if this will help.
Cptkid570
Ensign
Thank you Don! This sounds stupid, but do the parts install in the same order as the diagram shows/ I didn't realize that the thermostat went in first..Does it sit down inside of the thermostat housing so that the spring part of the thermostat is actually inside of the block?
I guess I just thought that the sleeve went in first and then the thermostat sat on top of the sleeve in the top portion of the housing (just below the V-thing)
What is the purpose of the sleeve? Does it somehow hold the thermostat down in there or is it used to direct water?
I didn't think that the thermostat was big enough to stay at the top of the housing without that sleeve going in first...
Sorry I seem so confused on this...
Windykid
I believe the sleeve looks to be a spacer to hold the thermostat seated. And yes install in the order seen in the diagram.:)
Cptkid570
Ensign
Thank you for your help.. sorry for my asking about something so basic, the diagrams in my repair manual weren't as good as the one you posted..
Here is another picture.. does this look right now?
Don S
Yep, that's the way it goes.
All that drawing is is a parts breakdown, I just blew it up a little and added the text for items 5,6,and 7.
Cptkid570
Ensign
Thank you Don! I really appreciate the help on that!
