thermostat location lf225 txrc
erniefish
i am helping my fishing buddy tune up his motors, i am good with water pump, plugs ect. but four stroke thermostat , on this motor is it under the coil bank? the service guy had him service the fuel filter on top of the motor , the one i never knew was there, that right angle contraption camoflauged with rubber was fun, any ideas, thanks e
rodbolt
Re: thermostat location lf225 txrc
one on each head, the port side requires removal of the ISC valve to access the stbd side remove the two bolts holding the plasic fuel line holder,remove the phillips head screw that holds the line then remove the tstat housing bolts.
DO NOT drop the bolts behind the intake. they can get hard to retrive.
takes me about 30 minutes to replace a pair of them.
are ya gonna ask about the pressure control valve ? :) :)
erniefish
thanks for the help RODBOLT, as always your knowledge is appreciated, and should i ask about the pressure controle valve?
