I am trying to replace the thermostat in my mercruise 260/350 engine. I bought one new with a gasket set which is confusing. The parts are the correct ones for the engine but there is one gasket that would totaly close the thermostat hole. Why would one completely close the water flow?
Another thin gasket with oblong bolt holes would just close the square hole part above the thermostat. Isn't this a bypass for the exhast cooling before the thermostat opens? There is one that would not close the square hole ( my guess this would be at the intake manifold) and one smaller gasket(cork) that looks like it would sit under the thermostat lip. There is a rubber O ring the size of the smaller gasket. I have no guess on this one. This is a raw water cooling setup with four hoses from the lower thermostat housing and two hoses from the cap. There was no thermostat in the thing from the start so I don't have the old one to go by. The thermostat does go under the two hose cap and not on the intake manifold itself, right? I have a manual but it is totally useless about gasket details. Also when are restictor gaskets used on the exhaust and when not? This is a center riser setup. Any help out there for this puzzel?
