Thermostat question
Gradywhite3535
I have a 1975 johnson 6hp and i replaced my t stat and don't know if the seal should be on top or bottom of tstat? Also if you look at the pic the water in my bucket seems really dirty like theres oil leaking. Is this normal?
Gradywhite3535
Re: Thermostat question
Does anyone have exp with this motor??? I would like to know if the seal should be on top or bottom of t stat? Thanks
Gradywhite3535
Any suggestions, i would like to know the right postion of this seal thanks
boobie
The seal should be on the top. It also looks like your thermo is bad being stuck open like that when cold.
Gradywhite3535
Well in that pic i just took it out and its hot. Thanks for your help
