I have some separation of the hull and deck on a McKee craft foam filled hull. I think the original adhesive probably set incorrectly, and now around the whole boat there is around a 3/16" gap. I've attached a cross section below.
I think I need to fill the gap then put a strip of glass tape to provide more strength. I am evaluating several options for filling the gap.
First of all, I think I need to use a caulk gun, or some type of injector, to get resin inside the gap. I've heard about cutting the corner off a freezer bag or using a putty knife, but I'm not very confident either of these methods will work. So here are the options I'm thinking of:
- West Six10 (http://westsystem.com/ss/new-six10-epoxy-adhesive/) ... Comes in a caulk tube and should do the trick. Pros: simple, Cons: expensive @ $20/6oz tube, not as strong as 105 epoxy with milled fibers
- Bondo Polyester Resin Jelly (http://www.jamestowndistributors.com/userportal/show_product.do?pid=6115) plus west fillable caulk tubes (http://www.westmarine.com/1/1/16096-810-fillable-caulking-tubes-from-west-system.html) ... Pros: cheap, Cons: may be hard to get into caulk tube, weakest
- West 105 resin + 205 hardener + 403 milled fibers + west fillable caulk tubes ... Pros: strongest, probably easier get in caulk tube than jelly if I thicken afterwards, Cons: more expensive than jelly
Does anyone have any advise? Thanks!
