Re: Thinking about painting my boat so what kind of paint?
Briteside, for example, calls for sanding with 220 grit paper, prior to application, and 320 between coats. No primer is necessary on bare fiberglass.
There are orbital sanders that take 220 paper. I would start there. Use the 320 grit between coats w/ plenty of water. Unless you have an air sander, elbow grease is the only way.
I would recommend either the roll and tip method fo painting (especially for the bottom), or a compressor-driven sprayer. These give the best finish. Spraying takes some experience, so you might get some cheap paint and practice on a fence or something.
The Marine Polyurethane paints (one or two parts) are real tough. I once spent 15 months sanding and painting my speedboat. On it's maiden voyage, my wife puts on the waterskiis and walks across the deck I just painted. Those skiis had metal skegs. The paint took that abuse, so I was able to remain married, and out of prison.
