StarGazerI
- Joined
- Jul 24, 2011
- 47
I was going sailing in Maine for a week with my wife. I took my motor to my mechanic to give it a checkout before the trip. Spent about 400.00 and the said it needed a new shifting arm F-N-R on the NS5B. We set sail and motored out of the harbor and set sail for islands unknown. As we approached our destination I tried to start the motor..it would not start. After pulling my arm off trying I did all the checks everything seemed good. Humm I decided to check for spark and found my spark-plug like this..
I have to tell ya! I had not a clue what this was. Proceeded to clean the plug and check spark was good. After reinstalling plug.. motor started first pull and away we went. The next morning went to start and the same thing, it would not start. cleaned the plug and go.. :facepalm: After our trip I took the motor back to the shop and the tech called me and said.. its DEAD
He said it was running in the tank and just died and wont restart. he said "You need to buy a new motor" I said OK and proceeded to pick it up and try to digest it and take it apart piece by piece to find out what happened to it. Here are my findings to date:
Please note: That the reason the engine all of a sudden died.. was the filter got sucked into the carburetor see carb pic. What I found on the plug-sludge was the engine had a water leak from the water cooling system. The Tech took the motor apart to change out the Drive Arm and didn't change the gasket after opening the engine. Thus, causing the water to leak into the engine.
Soo!! This is why you should always check what they did and who's doing the work and their abilities to do the job... Oh! Buy the way a motor gasket is only $5.08. Rule of thumb "If it has a gasket when you take it apart.. Tell them to REPLACE IT! its not worth the the $5.08 savings. StargazerI
