This doesnt sound good.
Don S
Re: OK folks i am sitting down, please give me the bad news
It's a core plug (Ford part no doubt) measure the hole, pull the pieces of the old one out and install a new one.
artificialreef
So thats the same as the one that is on the back of the head also? Only easier to get to :)
Don S
Yeah, same thing, on the 460 V8, the head could be used on either side of the engine.
artificialreef
Holy Moly, a freaking 10$ dollar part. How often does that happen with a boat. Theres one for the record. Don, Stoney and all you folks are incredible. This tub may see the water soon after 5 years in drydock. Im ecstatic. Thank you again.
artificialreef
Re: This doesnt sound good.
Just posting solution to my ticking. Stony was correct. It was the thermactor plug but on the front. The tissue trick would have worked because i was listening intently and found the noise louder towards the bow of the motor. I was moving my hand around the front and felt some blowing. When i got closer i found it. Stuffed a paper towel in the hole and the ticking went away. Didnt know there was one on the front. Thank all of you above. I now will have 2 good running 470's that havent seen the water for 5 years. Good compression. Running cool. :) You guys on here are so generous and patient with your advice. You are awesome.
Thanks again. For what its worth i try to buy all my parts here on iboats when available to support this great forum.
Don S
Just merged your two threads together, might as well keep the solution to the problem in the same thread as the question.
