:redface::redface:I've just finished building the hull and hooking up the controls. I was just about to come apart with anticipation. The motor had been run periodically on muffs over a span of 4 years. Each time with seafoam in the pre-mix. All the hours and hours of work to finish the resto of a '77 tri-hull. I dumped the oil in the gas tank, put in 6 gals of fresh gas, 6 oz of seafoam, launched the boat, only to have it sputter, cough, and die when I tried to accelerate. In my hurry to road test this project, I absently mindedly dumped a whole quart of penzoil 2 stroke oil into 6 gals of gas. That puts the mix somewhere in the range of 24 to 1 ratio. A far cry from the 50 to 1 it's supposed to get. I need to mention the VRO unit was ditched in the build. The conversion accomplished with the help of this board. A straight Johnson fuel pump does the work now.So.... here comes the dumb question from a 2 stroke outboard newb-rookie. I'm a pretty good shade tree but a 2 stroke outboard newb to the max. Would that super rich oil ratio, which is really double what it should be, cause this motor to refuse to run at anything more than about 2000 rpm under load? It ran great at idle and up to about 3 grand on the muffs, with the right ratio, but when I loaded her up with all that oil in the pre-mix, it would not run out at all and came back with wet, blue (the color or the oil) plugs, all three plugs were the same, coated in wet, blue liquid. The plugs are the recomended Champion QL77JC4. Can you say duh...... I was ready to pull the carbs down and go through them, with the multi-year span since it had been run hard, being the main consideration behind a move like that. But if I can avoid going through these carbs, I would love it. The kits are about $20 each, so I was just going to disassemble, clean, and reassemble.The budget is so tight. Whoever did it last used kits with rubber bowl gaskets, instead of the 1 use paper type, so I was going to just takem apart and cleanem up. Yes, I do have a J/E factory manual for this motor. Do the carb gurus think that getting the mix right will allow her to run right, under load? Or should I still plan on pulling the carbs down for a cleanup, a task I would avoid if at all possible. What say the J/E motor heads that work this board?? Thanks in advance, Kevin:redface:
