this motor will not beat me, with your help
Blue Bird
1972 55 Horse Chrysler 555HF, I have been reading as much as I can on this wondeerful site and I have learned alot but I still have questions.
Today I changed the fuel pump it was deformed and stretched out so I know it was neededand it does run better but not right yet still shakes and wants to stall and sometimes does.
It got late while doing the pump and checking it and then I saw it because it was dark I noticed the forth of july going on under the flywheel I can only see well on one side but it looked to me like spark is jumping from the outside of the magnets to the flywheel or the plate and everytime this happens the motor will shake, so I would like to know if I am seeing the magnetor working when the air gap comes around (generating elec) or am I seeing something that should not be happening I believe its the later and it is my problem if so what is the remedy, please help the weekend is comming
Blue Bird
Re: this motor will not beat me, with your help
Come on you guys cant anyone tell me if I should be able to see any spark under the flywheel at all... this motor is a magneto w/points
jerryjerry05
You shouldn't see any spark.It might be a bad plug wire arching like you see on old plug wires in a car.J
Blue Bird
Thank you, just as I thought I know leaking spark is not good I just didnt know if the mag made similar spark as the magnet came around. I will solve this problem next.
moonfish
I was gonna say the coils may be cracked but the leak could be anywhere.
