********** thought I meant brake pads instead of a fuel filter so Ring Free question
Natty Light
so I gues I'm going into the weekend without the new fuel filter I wanted to put on.
http://forums.iboats.com/yamaha-suzuki-outboards/help-changing-fuel-filter-v150tlr-2-stroke-carbd-607741.html
Hopefully their customer service can get it sent overnight. While calling around for this filter that nobody has a mechanic told me over the phone that he thinks it is the carbs. I'm sure that's possible. I'd like to be change the filter anyway if I could.
My plan for the weekend since the new filter may not be available is to dump a whole 16 ounce bottle of ring free into my 30 gallon tank.
Perhaps that will clean up enough of the system so that I can get through the weekend without the problem getting any worse at least.
Is it possible to overtreat? I know this isn't exactly a shock treatment (2 to 1) but it should do some good right?
I normally run ring free through every tank at about 1 ounce per 10 gallons or as close as I can get to that by eyeballing it.
robert graham
Re: ********** thought I meant brake pads instead of a fuel filter so Ring Free quest
I do not understand your question or problem?....could you please explain...thanks
JB
You would have done a lot better to add this to your original thread, Natty. Making it difficult for helpers to help is not a good way to get help.
