Thought Provokers - TCW4, TCW5
Stromzilla
Some of you may have a problem with the following thread so I'm giving you fair warning - if you're on oxygen, turn it on/up, if you are on medication use it, if you're bouncing off the walls from too much caffiene come back later, and if you're on a sugar high just wait a while before engaging.
Provoker #1: Create an all new specification called TCW4. This specification will be modeled after the TCW3 specification. However, it will show performance improvements across all categories with a serious improvement in 1 particular category. This specification will supersede TCW3 but will not eliminate it. So if your application calls for a TCW3 specification then you can use either a TCW3 or 4.
COMMENTARY: I've long felt that TCW3 was a marginal specification especially in one particular category. If you've torn apart outboard powerheads as I have I think you'll be able to guess the category. There must be hundreds of brands of oil that meet the current TCW3 spec. If I have it my way I'm guessing 75% or more of the current TCW3 oils would not be able to qualify to the new TCW4 spec. This spec would be for "old" 2-stroke technology meaning not for Direct Injection. Don't worry guys - for those of you that like your $1.25/qt oil you'll still be able to get it but it'll have to be as a TCW3 oil. Why am I doing this? It's a lousy specification in part because it got caught up in politics. When you have the hen guarding the henhouse things like that happen. Put me on the specification committee and I'll kick some booty and make the next specification right.
Provoker #2: Create a TCW5 specification. This specification will be targeted for the Direct Injection applications. The motor required for the qualification of an oil to this spec will have to be either an Optimax or Etec...we can decide that later. I suspect the same categories as used in the TCW3/4 specifications could be used. Allowable levels of performance in the specified TCW5 categories would be similar to the TCW4 spec. The key difference between TCW4 and 5 will be in what motor has to be used during the qualification process.
COMMENTARY: We need a new spec for the Direct Injection motors. TCW3 min/max requirements simply won't cut it. Because of the 2 oil flow rates for the Etec's we may need a 5a and a 5b to cover the 2...not sure on that one. Or we could force it to the lean-mode only but then that would upset the XD-50 users. TCW4 won't cut it because it'll be the wrong motor during the qualification process. Put me on the committee for this specification and I'll make it right
Let me know your thoughts. Keep it clean and let's not have any personal attacks. We're just having some fun. I am serious about my feeling towards the TCW3 specification though. I don't know who was a part of that specification when it was created but I'm willing to venture that more than a handful of oil manufacturers had something to do with it.
Frank Acampora
Re: Thought Provokers - TCW4, TCW5
HUH?
Elaborate and give specifics and then maybe I can get excited and take my chill pills. --or maybe just a couple of hits of Mary-Jane.
bassman284
We get it, strom. You're selling Amsoil. Give it a rest.
ondarvr
I will predict nothing will be done to improve 2 stroke oil because it's a dying product. There will always be smaller specialty companies making them, but the large oil companies won't want to spend money on a declining niche market.
jimbo_jwc
Ship Happens
Grandfather always handed me a can of non-detergent 30wt and watch me pore in gas can and say that should be enough , I have his 1949 Johnson Sea Horse and still take to the River and run , Has backward looking screw prop . Never been oil related issue .
pecheux
I feel the same about the Tc-w3 specification. I see as many (if not more) "meet or exceed tc-w3" as the "real M'Coy" but nobody seems to care, but when company Axxxxx writes "to be used for Tc-w3 application ... it's an oil war. (no I am not an Axxxxx dealer) and I would probably use Penzoil synthetic if it was available in local stores. I just find the Tc-w3 to be strongly overrated. Nevertheless I do agree that the Tc-w3 rating is a good base to law down the parth to good oil. One of my relative was working for Castrol and according to him all petroleum based 2 cycle oil are basicaly the same and most additives are also approx the same or give similar protection. End result is that Tcw3 is big $$$ business and that is the REAL oil war. LOL Cheers.
ajgraz
OK mystery writers, please reveal what the problem with the TCW-3 spec is?
JB
Translation: "Thought provoker" means troll.
Sprky
I thought that was my designation!
V153
HUH?
Yo Frank I hear hemp oil is the next big thing ...
HT32BSX115
Actually I think you have a great idea...........Although I think you might be in the wrong place to present it.
Maybe you're not aware of the group that actually does this very thing......... so If you click on the following link it will hook you up with the right place.
You can probably even call them and ask them if a "TC-W4" or "TC-W5" spec is either planned or "in the works"!
Although, I think a 2-stroke DFI spec is either available or planned .............I seem to remember something like TC-W3xx etc
http://www.nmma.org/certification/certification/oil/default.aspx
Oil Certification
The design of marine gasoline engines, both two- and four-stroke, have advanced to the point where higher output engines place severe demands on engine lubricants. Likewise, concern over pollution has increased fuel/oil ratios, which, in turn, increase lubricant requirements. To help boaters recognize lubricants that will give the engine life designed-in by marine engine manufacturers, the National Marine Manufacturers Association (NMMA) has developed a program for the certification of these premium quality lubricants.
The entire NMMA Marine Oil Certification program consists two parts, a certification program for oil additive packages and a registration program of oil brands using certified oils.
The registration for marine oil brands is conducted on an annual basis. All marine oils registered with NMMA are listed on this website. The TC-W3? symbol signifies a marine oil designed for two-stroke marine engines, the FC-W? symbol signifies a marine oil designed for four-stroke marine engines and the FC-W(CAT)? symbol signifies a marine oil designed to be compatible with four-stroke marine engines having an exhaust after-treatment catalyst............
All of us discussing it will go nowhere!
<For the person that said something about some "TC-W3" marine oils not being registered by NMMA, I highlighted their claim above.>
(by the way, I have no affiliation with any manufacturer OR NMMA)
Cheers, Y'all
Rick
Stromzilla
I've used mineral oil too and with success.
Stromzilla
Cheers, Y'all
Rick
Going nowhere...got that right, but that's ok. Thanks for the link...will check it out.
aerobat
Master Chief Petty Officer
can you just tell us why the (ams)oil discussion is such a brainer for you ?
pecheux
Frankly I have used all kinds of outboard 2 cycle oil with many brands of motors some were tc-w3 certified, others not, and except for less smoke with synthtetic oils I have not noticed any difference in motor performance nor had any oil related problem with any of them. (3 to 115 hp over half a century) So IMHO they (oils) are all good enough for the job ... tc-w3 certified or not. Nothing wrong with the certification.
jimbo_jwc
Ship Happens
Nothing like the smell of Klotz in the morning on my MX bike and seemed to cost to much to use in anything I wasen't racing or flying ?
