deeman7777
- Joined
- Sep 29, 2005
- 51
Saw a boat that has potential but I have some concerns on the engine / outdrive.
The owner claims it has under 100 hours on the engine - but there is no hour meter - I checked too and did not see one.
The outdrive has some galvanic corrosion. On the plus side it was rack stored but I am not sure how often the boat was pulled since I assume the corrosion takes time while batteries are charging or a reaction between different metals can occur. The interior headliner also has some water stains around the windows / ports. Not a huge concern, but perhaps the boat was left in the water for longer than the seller leads me to believe.
Anyhow the engine is a 98' Volvo Penta 5.7 GS model which is a carb'ed engine. The drive is a VP SX Cobra single prop.
The engine did have some standing oil (maybe a capful) on the starboard side below the carburetor (along the stbd side cylinder covers.
I am deciding if it's worth getting surveyed or not. I know the seller is anxious to sell. Here are some pics. Main concern is the corrosion and whether it's worth pursuing a $500 survey. Thank you!
