Donzi GT250
Thread starter- Joined
- Apr 22, 2011
- 110
The thread insert #75 on my OMC cobra came out when removing the bolt that holds the transom mount cap #28.
The threads on the bolt where buggered up causing the thread insert to be stuck on the bolt.
Also as best as I can tell the threads in the transom mount hole look to be buggered up also.
The real issue I have is access to the bolt hole as the clearance between the top of the transom mount and the swim platform is tight and I can't get a drill or a thread insert tool in position to re-install a thread insert into the hole. Also like I said the threads in the hole that hold the insert in place look to be messed up.
So I am lost as how to proceed to fix this issue.
Any ideas?
Thanks
http://www.boats.net/parts/search/OMC/SternDrive/1989/350APRMED/TRANSOM MOUNT/parts.html
Any ideas?
Thanks
