three questions please
plugger
Better to run thru the tank of stored gas (35gal) before changing the fuel/sep canister or adding the carbon guard fuel addidive ?<br /># 2<br />Should plugs be recleaned at that time?<br />#3<br />this will be the 4th season with the boat and it seams to me that the shift control lever is "lower" to enguage reverse than i remember it being.do these streach over time or is there an ajustment to shorten the travel of the lever....it all works fine but if this isv an indication of wear i want to get it serviced <br /><br />thanks in advance
D
DJ
Guest
Re: three questions please
1. It really doesn't matter.<br /><br />2. You should replace the plugs after a decarb.<br /><br />3. Yes, cables can stretch. I would look, first, for loose linkages.
Solittle
#3 - Do not try to ease it in gear. Engage solidly.
dajohnson53
Originally posted by DJ:<br /> <br />2. You should replace the plugs after a decarb.<br />
The only other time I decarbed I changed plugs afterwards, like you recommend. But, what do you think of the decarb method described in the FAQ - which claims that the plugs don't necessarily need to be changed after decarb - because they are also cleaned? I just did this method this weekend - but did not have time to pull the plugs afterward to check if they really were cleaned or not. Actually they weren't that old so I don't know if it would have been relevant anyway. I tend to change my plugs each spring and again during the season if I'm running it a lot anyway, but I thought I'd point out that FAQ and what it says re: plugs.
quantumleap
Master Chief Petty Officer
If you pull them, you'll see a bit of gunk around the edges that can be easily cleaned off. If you wait too long, it'll bake on. Plug are cheap though.
dajohnson53
Originally posted by Quantumleap:<br /> If you pull them, you'll see a bit of gunk around the edges that can be easily cleaned off. If you wait too long, it'll bake on. Plug are cheap though.
And how - my attitude is when in doubt, change the plugs!
Bass Runner
It's my attitude that if it's running good and dosn't miss why change them, if it aint broke don't fix it. :D
Oldsaltydog
The plugs were almost new when I decarbed. Cleaned plugs afterwards. Runs like a watch now. Right on Bass Runner!
