mpdive
Thread starter- Joined
- Apr 23, 2011
- 567
Gmorning....I just did a carb rebuild for a friend on a 2006 Tahoe 4.3L. Carb sounds great after we installed it in the driveway. Put it on muffs and did the initial adjustments until we can get it on the water to make the final ones. When working the throttle from the controller, it does not want to return to base idle and visually you can see that the idle speed screw is not contacting the stop. After running it at 1500 and then pulling the throttle back to idle it want's to sit at 900 rpm's. I removed the linkage to assure the throttle body was not binding and it goes right down to base idle. The throttle cable is a grey cable and appears that it runs along the inside of the boat unsupported. I am not a throttle expert and don't want to start turning adjustment barrels unnecessarily. Does this sound like a binding problem or adjustment issue?
