Throttle cable adjustment
Hi Everyone<br />I have a 1988 force 50HP on 20' pontoon had it out last weekend and my forward throttle <br />travels 3/4 of the way between n and WOT before I get any change in RPM's and RPM's at WOT <br />are only 4000. Is there any adjustment on the throttle cable to give me better responce with <br />throttle controls? <br />Thank's :confused: :confused: :confused:
D
DJ
Guest
Re: Throttle cable adjustment
bigbronco,<br /><br />Look where the cable attaches to the gear shift lever and throttle under the hood of the engine.<br /><br />There should be some threads on throttle cable end to allow adjustment.
Thanks Djohns19<br />That won't throw off my timing or anything like that will it
D
DJ
Guest
It shouldn't. As long as you adjust the cable-ONLY.
