Re: Throttle cable - Is this normal?
Those look like the old 400 series control cables. If the end play is not at the set screw points you video taped, then the end play is in your control box at the helm. Those cables are straight through from the control box connections to the two set type screws at the control area on the engine. Check to see if the set screws are tight and then work from there to the control box...
