throttle cable question
fordmxracer
I bought a ch1700 throttle control and not sure which cable holes to hook it up to.
I have a 98 wellcraft excel ssx with a 5.7L mercruiser carbureted
Coors
Re: throttle cable question
No instructions as to use this hole for.. that hole for...?
airframer
just move the control threw both directions of travel, it should be self-expanitory. one will move all the way up and down(throttle) and one will move slightly in both ways(condition)
Coors
The teleflex I bought, had 3 different holes, one set for omc, one set for merc, one set for....
fordmxracer
it had about 6 different holes to mount the cables to. half I think are for push throttle cables and the other half are for pulling cables. I just dont know which are for wich. I tryed to compare to the original throttle and they were a bit different.
fordmxracer
Just want to thank everyone for there help but teleflex support answered with the exact holes I need!
Thanks again guys
P.S. If anyone got to a teleflex ch1700 side control and have a 1998 wellcraft excel...well here you go
"Ryan for your throttle you would use the 2 and the 2 holes which would be pulling your throttle cable as you push the hand lever forward.
The shift cable nest kit hooks to the 7/8 hole and then the end of the cable hooks to the 7 hole which again would be pulling the control cable to shift into forward gear when you push the hand lever forward
Jim at Teleflex tech support."
