Throttle Cable Slack
LAC_STS
As in the video when in N there is no slack in the throttle cable at the carb. If I put it into gear or raise the RPMs without putting it into gear there is a ton of slack in the cable at the carb. So sometimes when I am throttling up the RPMs will not be steady and go up / down a little.
Even if I have somebody hold the shifter and make sure it doesn't move I can still move the throttle cable like in the video. It's like there's a bunch of slack in it but it doesn't do it when in N.
Does it sound like I need a new throttle cable?
http://www.youtube.com/watch?v=QDOqcFHYpFw
Ayuh,...... If at Idle, the control cable is puttin' a slight pressure against the throttle stop screw/ idle screw on the carb,....
And,.....
At Wot, the throttle plates of the carb are at full vertical in their bores,.....
The throttle is workin' perfectly,......
