Re: Throttle Control Assembly Diagrams
No need to buy a new one, Nath... I took my whole assembly apart once to lube and clean it. NOT an easy project. Geez... But all we have here is the pin and rod in the handle. It would be easier for me to show you rather than try to tell you how it goes together. It is kind of screwy...and I had to put mine together several times before I got it right. It will go together several ways. If I remember right..the pin has a notch on it. Make sure that is engaged in the rod that goes down to the bottom. As for the top bend going into the handle button...that is where it would go together a few different ways. The best thing I can tell you from memory is to put it together without the cover. Hold the rod from falling out with your hand and see if it works right. If not, put it in the other way. I hope this helps...it's been a while since I have been into one of those... As far as the manual goes...I don't think I have one that shows that version...
